Ok I have an issue I havent encountered up until last night. I was assembling the new water pump housing and getting it ready to install on the LU. I was using a tap to clean out the threads as I usually do just for good practice and on the last hole the tap broke off inside.... Im not able to grab the tap with anything and I am at this point unsure what to do. If anyone has run into this problem could you help me out? The drill bits I have will not penetrate this tap I spent about 2.5 hours trying to get this thing out and have used a dremel to gut a slit in the tap to put a flat head in there and back it out but to no avail. This sucks!
