FloronGlenn
- Feb 18, 2004
- 11
Pulled gear case to replace impeller. Impeller was rusted to the drive shaft. Cut it off with dremel tool, could not get key out. Put in new impeller following the manual. Had to go with old key. Could not get impeller plate off due to rusted key so did not change the plate. Put it back together, not getting any water thru motor. Any suggestions?<br /><br />To get the gear case off, had to cut the blue and green wires going to the shift solenoids. Spliced them back together (thought I did a good job), tight fit getting them back under the solenoid cover, but got them in. Have neutral and reverse, but no forward. Had it before. Could my splice job be the culprit? Going to tear it down AGAIN tomorrow, any help or ideas will be greatly appreciated.
