So I finally got this thing running on both cylinders but I still have 2 big issues with it. One being that it only pushes my 1988 alumacraft deep v lunker at about 15mph and correct me if i'm wrong but I think it should push this boat double that speed? The second issue is that I foul plugs like crazy, mainly the top plug. I try adjusting the low speed rich/lean and high speed rich/lean knobs but they don't seem to make a bit of difference in how the engine runs no matter which way I turn them. I checked compression and i'm getting 115 in both cylinders. I checked for a spun prop hub which I found it does not have. Can anyone help figure out why this engine that starts up no problem has good compression has no power?
