So myself and two of my roommates bought a older boat that we want to use for fishing/skiing/tubing/babe cruising( ). Anyways we got it dirt cheap.
It has an older 60 hp v4 evinrude outboard motor. Only problem is that the motor is not wired up and installed 100%. I'm wondering if anyone here has any boating experience(such as installing an outboard or just outboard/boat experience in general...)
It has what looks to be most of the components needed. Right now, I need a gas tank and battery for sure. There also seems to be a bracket missing that holds the steering cable in place and a bracket missing where it connects to the motor. Anyone know where I could get something like these brackets?
*edit* Did a lil research again and its rack and pinion steering..
Also is there any way to tell the type of steering system it uses? Hydrolic cable or rack steering? It looks to be hydrolic.
Can anyone help us out, point us in the right direction. Any good websites or forums that would be helpful?
Thanks in advance.
Jason
Thanks in advance.
Jason
