this thing has officially ruined my weekend...I have a 71 100hp johnson that was running fine last week. took it out friday and it had a horrible missfire on cyls 3&4 so i rebuilt the carbs, replaced the plugs, gap on the points is .010. the amp box is less than 1yr old, and now it runs worse than before. it still misses and wont start without the throttle fully open. ive adjusted and re adjusted the slow idle screws about a dozen times. Can anyone help me out? im ready to turn this thing into an anchor!
also there is no water in the gas or in the cylinders and compression is around 120 per cyl.
thanks
thanks
