I have a 70hp 1970's model chrysler outboard and it seems to starve for fuel at wide open throttle. When you first open it up it runs fine, and after 10 seconds begins to miss. You can actually see the fuel start to run out in the sight glass on the fuel pump. I have rebuilt the fuel pump and there is new fuel lines running from the tank. Back the throttle off just a touch it it quits missing. I have johnson quick disconnects on the fuel tanks and have the breather open. The fuel line from the tank is 5/16". Suggestions on the reason for the fuel starvation. Are my fuel lines adequate size or do the need a different disconnect to provide more fuel. The vacuum lines are also new to the fuel pump.
