I have a 1970's chrysler 70hp OB engine. There are two holes with screws in the lower unit that are labeled for the gear oil. One says grease fill which is the lower and the other says grease level which is the upper. Right below the grease level hole which is at the top, there is a hole that is empty right now and is 2 inches below the grease level hole. When I was adjusting the trans cable moving the throttle lever into forward and reverse some milky looking grease came out of this unknow hole. What is this hole for and should it have a screw in it. I checked the lower unit oil and it looked fine with no water in it. The hole looks like it has threads. What gives??
