Nathaniel McLellan
- Jul 12, 2013
- 9
Hey guys,
First time poster, nice to meet you all.
As the title states, I own a 15ft runabout with a 60hp Johnson Hydroelectric Shift. I know the motor gets a lot of bad press, however it's worked great for me so far in that aspect. However, earlier in the summer it began only starting once in awhile. Sometimes it would kick right on, other times it would just click. A few times I had to jump the starter directly with a set of cables to get home.
I assumed it was the solenoid, so I bought a generic 80A replacement from Princess Auto. It was 4 post similar to the one that was there already:
However, after disconnecting everything I got distracted with a different boat project and didn't end up putting the new one in. Fastforward two months and I'm getting it ready for winter and want to get this buttoned up. I don't remember, however, how to hook everything back together. I've numbered the different connectors on the engine and alphabetized the new solenoid to make anyone who takes their time to help me life's a little easier. I do appreciate any help rendered.
1 - goes to the starter
2 - this comes off the engine side of the harness. I believe this is the charging wire to recharge the battery. I know that this and 5 go together.
3 - Comes from the engine side wiring harness. I do not know what this is.
4 - I believe this is the starter wire from the key. It comes from the boat side of the harness.
5 - This is the positive battery wire. As stated before, I believe #5 and #2 go together.
I am unsure at this point which wires go to what posts. I know that #1 (goes to starter) goes on one of the two larger posts, with #2&5 go to the other. I am unsure which goes on which though. #3 and #4 must go on either B or C, however I am unsure which.
Any help would be appreciated.
Thanks,
Nate
Thanks,
Nate
