more work today...still wet and raining. Finished the temporary installation of the second broken rib, Only one rivet hole was out of line. When I get some dry weather I will clean up the rib area, 3m-5200, and invert the 10/32 bolts on the ribs....epoxy between each piece of 1/4 inch flat bar.
Placed a patch over the corroded drain hole. I need dry weather to make the corroded area smaller with JB Weld, then sand, then 3m 5200 again. I plan on flat washer, lock tight on a nut, then a fiber nut on the 10/32's.
Cannot see it but the knee braces needs angle support...both sides are gone. I can use an extra piece of the Z bracket...cut in half. Should have both inside and outside of the aluminum transom pieces soon.
The epoxy for the transom needs dry weather....right? I plan on using Watermans glue for the two pieces of 3/4 for the transom...I found the glue!!! $9.00 a tube...two tubes should do it.
the more I read other resto's, the more I feel this hull is in GREAT SHAPE!. Just luck...as I have not flipped it yet, but the bottom and transom looks good...a lot of extra holes from previous owners, but that can be fixed. Over the last 4 weeks I have read the equivalent of War and Peace about 5 times on Restoration threads...so much good information and good reading. Thanks to all!!! Ron
You're knocking out a good chunk of hull repairs, everything's looking good and well thought out :thumb:
On track for a summer splash, keep plugging away!
BRon,
Do you think those two transom pieces were original? They don't look like anything I had on my '67 Starchief. It had a differently shaped plywood piece on the outside and only the transom wood inside. I will be doing something similar on the outside to cover holes on my transom skin, and just ordered a 60" by 18" piece of 1/8th 5052 that I will cut to a similar shape as yours to cover the damage. The inside piece to protect the transom from motor clamp or bolt damage looks like a good idea.
OHRon
Thanks Ron,
You probably asked about me being an electrician for a reason. I am not, but my Dad and brother are lifelong IBEW electricians, both retired now and enjoying the benefits of being in a union after hard but rewarding careers in Michigan.Ron
Still moving forward. Had the wife help today with the transom. Used a light mat between the two pieces of 3/4 marine grade wood. Went smooth. Advice from this site led me to use about 175 pounds of even pressure on the glue job. Used Watermann's glue, will check in the morning. May need a little cut/trim for a final fit. Will need warmer/dryer weather for the transom epoxy.
Picked up the three sheets of 5/8 marine grade wood for the deck....$240.00 with tax!!! Double ouch!
On a quest for a 2014 Yamaha 60 4 stroke...found a new one with controls, prop, cables, tax, $6600.00. Not a speed boat, 25 mph tops in the Norther California ocean and Baja. Will post pictures tomorrow. Been following old haven and Decker83 with great interest. GREAT SITE!!! Thanks!!! Ron
