Re: 1970 Pre Alpha only took 1.25 quarts?
an mc-1 drive takes 32 fluid ounces......
But still sounds like your 1/4 of a quart short. Make sure the drive is level. If you pumped some air in along with your fluid replace the screws with the old washers and run it for a few minuites on the muffs and then recheck the level to see if it burped. After your happy make sure you put new washers on.
