I have a 1970 40HP Johnson and had to wire the switch myself. I am pretty good with wiring and such and did it in the military. But I have a problem that when I turn the key to the on position the motor starts. But it should start when I turn it to the next position to the right and then the key come back to the on position to release the starter. I had to replace the ignition and bought a ignition switch for my version of motor but the letters on the back did not correspond. I am unsure as to which wire I need to switch to what position to get the starter on to the correct post. I have a switch that has 6 posts one being for the push to choke. Thanks for any help.
