domwebhost
- Jul 13, 2008
- 117
Hi,
To those that are veterans to this forum you already know that I have a 1970 Johnson 60 Hp 3 cyl. (with wire terminal and monkey nutz). I finally took the boat out on the water today. I tried to start it and it would turn over and run VERY rough for anywhere from 5-20 sec. after which it would die and I would have to hit the key again to get it to fire again. It did NOT run everytime. Sometimes it would fire (and then I would hear the starter spin) and other times it would stay running for a few seconds. Things that I have done to the engine so far include: new plugs and plug wires, new coil, new gas lines ( between carbs) and new gas line (primer bulb assembly) I took off the flywheel and cleared the rust off of the inside of it and off of the contacts. Does anyone have any tests that I could do to try and get this to stay running? I also noticed that even though it was NOT in the forward position or the R position that I was still being propelled forward as I was trying to start it( and out of the water with it in the START position the prop only moves forward or backward about a quarter of a revoultion before it stops (as if it is in gear) Perhaps I will save that problem for another day ( unless someone has an idea about it) I am mostly trying to diagnose why it won;t stay running..... It has not ran as long as I have had it ( 2 yrs.) aside from firing it up out of the water real quick (which it sounded like it was running smooth, but my muffs don't fit well enough for me to comfortably leave it running for any period of time other than a few seconds. When in the water if I try to give it ANY kind of throttle it immediately dies. So, what do you think guys and gals? If you could point me in the right direction I will systematically do what you guys say to try and troubleshoot it. I am going to try to do as much as I can during the week, then take it out on the weekend to test it, then back to working on it during the week..etc.. so any help would be greatly appreciated
