Johnson 1970 won't run right with engine cover on?
S snostuddd Recruit Joined Jul 27, 2015 Messages 4 Jul 27, 2015 #1 Johnson 1970 won't run right with engine cover on?
S snostuddd Recruit Joined Jul 27, 2015 Messages 4 Jul 27, 2015 #2 Can someone tell me what I can do to fix this problem
Chinewalker Fleet Admiral Joined Aug 19, 2001 Messages 8,902 Jul 27, 2015 #3 More often than not, that means you've got an exhaust leak. Check the base gasket and exhaust cover gaskets for evidence of blow-out (oily residue). Occasionally, it may point to a spark plug lead being pinched to the belly pan and shorting out.
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 36,356 Jul 27, 2015 #5 So is this with the motor running in a barrel ??????-----Do you have a fan to blow the exhaust away ??
F F_R Supreme Mariner Joined Jul 7, 2006 Messages 28,195 Jul 27, 2015 #6 That was my immediate thought also. Running in a barrel? Get it out of that barrel and on a boat, on the lake, where it was designed to run. Then report back if you still have trouble.
S snostuddd Recruit Joined Jul 27, 2015 Messages 4 Jul 28, 2015 #7 I have run my other motors in barrel and had no problem with them choking out. I will test today at a close lake thanks.
