Re: 1969 Merc 110 Spark Issue
On any engine whatever the size the spark should jump 1/4 to 1/2 inch. If not there is an electrical issue thats all. This goes for any engine of any size that uses a spark plug. Simple my freind. People that read a post trying to find how to test a plug have information I posted helping them as well as this guy do a simple test. Then check for other issues. If your a supreem being on a 9.8 then this should be an easy hey gap it check it. That doesn,t seem to be the issue in 9 posts. Its a simple spark test and no BS new fangled tool or proceedures need to be made it is a simple test for SPARK! I do appreciate you telling him to cut the gap ground off to allow for the spark to jump though thanks Laddies That is an essential aspect for proper testing, but even a profesional like you should know that if the spark plug lug isn,t grounded the spark will jump to the nearest ground and therefore you just destroyed a good plug for testing. My BUHW OR BUHW-2 do not have the adjustable gap but still jump over to a 1/4 inch gap to any near ground as long as the lug is not grounded. I did have to come back and edit this as it is imperative information EDITED in last post "Test each plug in this manner and you should have a gap of spark fire of 1/4 to 1/2 inch. If the spark does not jump the gap and you ground the plug direct to the plug hole and see a weak orange spark from the plug center to the plug lug or no spark at all. then you have electrical issues.
