jimmbo
- May 24, 2004
- 12,973
Wow! You're learning just about everything you could ever learn about that engine design. Probably more than you wanted to know. I see you pulled the exhaust tube out. Yes clean all the carbon, it might reveal a clogged up passage. With the powerhead off you should be able to trace the path the water would take to the idle relief, probably find more sand. I hope in the end you have yourself a fine running engine
edit: in your picture, is there an opening where I drew the arrow. It looks like light is getting in there from the back
