Re: 1969 115hp Evinrude no start scenario
Underneath the flywheel you should find the black distributor cap, with the four plug wires and the coil wire connected to it. If you raise this and set it aside, and then remove the rotor (with wave washer on top of it), you should see the breaker plate and two sets of contact points. Is this not what you have? The ignition might be described as "electronic", but it's still "triggered" by two sets of contact points. It's just that they don't have any high voltage going through them, so are not susceptible to arcing and erosion.
