1968 18 HP Evinrude ignition timing
samo_ott
Re: 1968 18 HP Evinrude ignition timing
I see way back that you only changed 1 coil. Why only 1? did the other one look ok? If it is an old coil it might be failing spark under compression but passing the open air spark test...
