daveswaves
Ensign
- Mar 22, 2002
- 901
Re: 1967 Mercury 1100SS The fun begins!
Ed, a picture of the other side showing the detail of how the wires go into the distributor. The ones with two coils had a side entry into the cap for the second coil wire. Looks like you just have one coil wire, that does not mean one coil is missing it could have been converted. Your points are located under the distributor cap, inside the enclosed section. If you are missing 3 cyl then likely one set of points is either dirty or collapsed. Not a problem. If you need points I have a set here I will gladly send you.
