zephemeros
- Aug 14, 2016
- 2
I have a 1967 Johnson 6 horse, runs great and starts on the first pull even when cold, idles very low and never misfires.
I decided to pull the spark plugs today to see how they look after some recent heavy usage, and the bottom cylinder plug looked great, however the top cylinder plug was covered in water and had some milky grease on the electrode. Looking inside the cylinder it appears normal and I see no scoring on the walls, only a bit of carbon buildup, maybe a bit more than the bottom cylinder has. Compression is 85 psi on the top cylinder and 87 psi on the bottom.
It is possible that some condensation/water may have been in the gas, but not so much that the plug would be filled with water, or so I thought at least. I would think that such a large amount of water in the gas would result in poor performance anyway.
Could this be a head gasket issue despite the reasonable compression readings, or should I be looking elsewhere? Or is a bit of water in the cylinder normal and not something to worry about?
Thanks!
Thanks!
