Re: 1966 60hp stripped plughole
If you really want a shortcut, remove the sealing ring from the spark plug and see if it will screw in. Sometimes the very lowest threads survive. If not, you need to pull the head and tap it for helicoil or solid insert. I like the solid inserts. Put some epoxy on the outer threads to force it to stay in the head.
