sluffmeister
- Jul 22, 2016
- 5
This is my first post so please bear with me as I display some of my ignorance.
I picked up a '65 6 hp Johnson on Craig's list this week and the motor runs, but the pee hole is not shooting out any water. I only ran the motor for a minute, but I could tell it was heating up so I shut her down. I've since removed the lower unit and will replace the impeller. Here's where the questions come in:
1. I found some BBs on the floor of my shed after working on said boat motor. (It should be noted that I have also removed the lower unit on a 1957 Johnson QD-18 10 hp motor earlier, but I didn't notice the bb's while working on that motor). What would these bb's be from? I found about 6 of them so far.
2. I noticed that the Sierra kit for the impeller replacement comes with the bottom plate, or I can just buy just the impeller. What would determine if I need that bottom plate replaced? (Sierra 18-3202) Should I consider replacing any other components related to the water pump?
3. I purchased the motor without a top cowling cover for the motor. Anyone have a recommendation of where to get one in the Minneapolis area? I'd like to avoid shipping costs if possible.
Thanks for all of your sage advice!
