shadowrider
- Feb 19, 2009
- 195
Re: 1965 9.8 Merc overheating
That is a lot of good information to know. You explained it well, I have seen impeller bits while changing one but never thought about accounting for all pieces. The pump tube on this motor is only 3/8", hard to imagine peices goning up there, but it makes perfect sense.
I have a few old outboard blocks laying around, I will look at them to see what you described. I can also use them to practice removing old studs. Problem is some water jacket bolts are below top of pan, so they would not be drillable for easy out purposes.
Those would need a nut welded on if they break. I am considering removing the leg from powerhead,( as merc850 suggests) as those bolts dont usually break in my experience. That would give me access to most of water jacket, would it not ?
