Re: 1964 evinrude 40hp
That's low. When I started working on mine, compression was only 85, and it ran. Can you describe how you did the compression test? If you did it incorrectly, that could account for the low compression reading.<br /><br />If you did it correctly, there's still hope. It's entirely possible, if both cylinders are the same compression, that the head gasket is leaking. That's easily fixed. If the engine has been sitting for more than a year or two, the rings may be stuck. That's generally easily fixed, as well.<br /><br />I'm assuming this is an electric start engine. If so, pull both plugs, screw in the compression gauge and crank the engine through several revolutions or until the gauge doesn't rise any higher.<br /><br />If it's still low, try laying the outboard on it's front, with the spark plug holes vertical and put about a shot glass full of Sea Foam or other decarboning fluid in each cylinder, and let it sit overnight. The next day, crank the engine to blow the Sea Foam out and repeat the compression test.<br /><br />If still low, then it's time to pull the head and have a look.<br /><br />These are very nice engines, very durable. Most parts are readily available, although engine internals can be troublesome to find. <br /><br />Lots of folks here who own Big Twins, so you'll get lots of help here.<br /><br />Let us know what you find.
