mheym56820
- Jun 4, 2006
- 3
Anyone have any ideas of how to remove the flywheel. I have a picture of it that I can e-mail you if needed. The flywheel is roughly 7 1/2 in diameter and I tried to use a 12" 2 jaw puller but it would not work. There are no threaded areas on the flywheel to allow use of a steering wheel puller. I need to get under there and figure out why I have no spark. I am thinking condensers and points, hoping its not the coils but I think that it is more likely that the points and condensers would go out together than both coils at the same time.<br /><br />One other thing, Can anyone confirm oil/gas mix. I had one reply to a previous post that though 16:1, just want to make sure and lastly can I run the standard 2 cycle outboard oil (TCW3) I believe or should I use something else when I get this thing fired up.<br /><br />Thanks for your help,<br /><br />Mike
