harry styles
- May 2, 2008
- 33
Hi
I have been trying to get this motor started with some success as in I puled the leg off and did actually get it to start however... I primed it today and the pump did not get hard and I had fuel leaking out of the bottom of the leg (leg is removed so It seems to be coming out of the crank case where the shaft goes in) Is this because the fuel pump diaphragm is leaking into the crank case and then out the bottom?
Thank you in advance,
Harry
Harry
