interalian
- Jul 23, 2009
- 2,105
If it's a press/tap fit, I'd consider using a flange sealer on it, like Loctite 515. And I'd consider replacing both and sealing both. JMHO.
Gee, it's been so long that I can't remember how it was cleaned. Perhaps I'll call that shop later today.
I don't want to booger up the existing plug just to find that it is stuck fast in there. I think that I'll play around with it to get an idea if it is loose or not. If there is any kind of play in it, then I will definitely press in a new one. Regardless of whether I replaced one or both plugs, I'll use the flange sealer that interalian recommends. I suppose that I should simply use an appropriately sized socket and tap it into place?
I'm thinking that cogitare is the latin root for cognition (thinking) and aedificare is the root for edifice (building). Is that correct? And the entire phrase taken together with the other modifiers means...?
