oldboat1
- Apr 3, 2002
- 9,607
Don't run on muffs (if your are), and never brag about success to your wife!
No needle seat would have meant the float wouldn't work, which would explain overflowing. If you have the needle with the black tip, you usually need a wire clip over the float arm to make sure the needle doesn't stick when the float drops (i.e., to allow fuel in).
I'm not sure what fuel mixed with water means in your case, but may just be unburned fuel from the exhaust. Happens when trying to dial in a motor.
