WaterLoged
- Nov 24, 2010
- 6
I recently picked up this fine boat. My first boat, and second restore I hate fiberglass now. Found her on CL for $250. The wood transom was basically dust the bench seats were rotten. I love that she had no holes other than the drain, so with a little persuasion my wife agreed I should get it.
This is how it looked when I brought it home.
I believe the transom was the original from when it was built because it was wider at the bottom than the top. The only way I see to put it back that way is to remove the transom braces that are riveted to the hull. I'm no expert but I don't think 3/4" will hurt the strength of the transom. I decided to modify the transom for a long shaft engine, I shaped the filler myself just have to get it tig welded in.
When I removed the rear bench I found out the seats were solid mahogany and the rear had this tag underneath,, I assume it was placed there by a previous owner . I have Mahogany to put back in I will have to glue up with gorilla glue to get the width I need
I striped 51 years of paint in 2 days I noted at least 6 different colors. It was a lot of work to get it all off but I'd say all that paint kept the hull from corroding. Heres the cleaned hull
Now shes ready for paint with a coat self etching primer.
I the weather will cooperates I'm going to shoot the first coat of Black top coat next weekend, I want to get at least 3 coats.
