FFScott6
- Aug 2, 2007
- 136
Hello,
I've been here before but I now have a slight problem... I'm getting water in the L/U about 8oz after running 12 gallons of gas. I get a total volume of water and oil out approximately equal to a fresh refill of oil L/U oil. (talk about a thirsty motor!) Anyway, I purchased a L/U seal kit and have cleaned everything and prepared for reassembly
The manual (a Gale original) says to utilize a puller to remove the Head & bearing Assy, I want to replace the oil retainer and head oring. What is the best kind of puller and what sis the safest way to reinstall without breaking the tabs protecting the 4 screws.
I'm guessing it has not been serviced in MANY years. roller bearings and other visible gears seem to be in nice shape little or no wear, scoring, end play etc. Don't let me kid you I do not own a dial caliper, so it's feel and machining experience.
As side note if you search my original posts, I had no knowledge of this motor, but with some points, plugs, fresh fuel, primary wire repair (new plug ends) I can get 25-28MPH on a 17' Aristo craft w/4adults and gear. The Gale planes this boat nicely and holds it up at a bit over 50% throttle. Just a bit of backround info.
By the way I've had to make a gasket or two... will it hurt to use a bit of silicone gasket maker to ensure a below the water line seal?
Thanks to iBoats mods and the rest of you as well!!!
Happy Boating - Scott & Dot
