1960 Starflite
- Jun 23, 2011
- 352
We have a 1960 merc 300 (35 hp) When we pulled the boat for this season (Ohio) we found a little water in the lower unit.
A little background: purchased the boat/motor early in the spring after it sat for 14 years. (some water in the lower unit) Feeling that the water pump impeller had to be shot, we replaced the impeller and upper seal. Ran the boat all season without any problems.
Now we feel that the lower seal or o-ring below the pump insert has to be bad or maybe the prop shaft seals. We purchase a OEM manual for this engine and it looks like a nightmare to remove the water pump cartridge/insert to get to the seal and o-ring without destroying the parts.
Questions: Has anyone here dived into this area of repair? Can the pump cartridge be removed without damage? Suggestions?
Thanks for any replies, Tom @ Buckeye Lake
PS; Not our regular usage boat, just an antique to play with.
