Re: 1959 Lake N' Sea Restoration
Some reinforcing work on the transom this morning. First, I had to get it CLEAN... The area between the transom and the louvers was a 'void'- It was supposed to be sealed off, but water had gotten in there over time. There was a lot of dirt and discoloration-
In order for the epoxy to bond well, It all needs to be cleaned up. I use a nylon abrasive brush on a drill- It's really handy for getting in to tight spots like this. It looks much better after some work-
The plan is to reinforce the weak spots inside the louvers. This is not a structural area- it is purely decorative- so it wasn't built that heavily to begin with. Some areas have cracked a bit, and the cracks will be filled from the inside. Then, I'll use glass tape to provide strength all around the edges. In areas where the joints are 'extereme'- as in a 90 degree angle, I'll use a fillet to 'ease' the edge a bit. The whole bottom of the louver has a 90 degree joint, and it has proven to be a weak point- It cracked on one side.
After a bit of work with some epoxy & microballoon filler, then some 3" glass tape-
This will be MUCH stronger than it was originally. This is probably all overkill, but I don't want to EVER have to do this again!
I may fill the void area using some expanding foam, though I don't think I really need to. It's only about 1/2" deep back there.
Next up will be repairing the damaged areas of the transom. Since some of the outer skin is missing, I'll have to build a form on the outside, and laminate new skin on. The form will also hold the correct shape of the transom, and keep everything in place as I lay the new glass on the inside to fix the cracks.
-Andrew
