If you have the shift rod disconnected and the bolts out, nothing else is holding it. Unless. Unless the last guy left that 10 cent o-ring off the top end of the drive shaft and the drive shaft splines have welded (rusted) themselves into the crankshaft. If that is the case, you have a problem ranging somewhere between minor and hopeless. Go ahead and force it off and see what results.
