Re: 1958 johnson 18hp wont plane
Dont sell the boat , and do not sell the engine.
and dont go paying out fortunes for longshaft kits neither.
just make a simple stand off bracket for yours and make it stand off 5 inches and youl not only have the right length motor, but
it will out perform a longshaft directly on the transom.
as for needing longer tillers etc, since when is a piece of plastic tube gonna cost a fortune to slip over it ? (white kitchen pipe !!!!)
the resuts by adding a small setback far outweigh any mods to the engine, you dont need any special tools, and dont need to
make it as strong as the ones i made.
your only talking of 18hp so make it strong enough for a 30hp and you have huge margin for strength.
if you have any angle alloy around then make it from that.
you can buy them but i just think its a waste of money when you will definitely find something to do the job just lying around.
it can be made from wood as long as you make sure the box structure has some metal on the edges to keep it firm.
i wish you lived close i could knock you one up in 5 mins flat and fit it as well for free as its a easy simple thing to do.
go have a look at these, you can mount these upside down to give you what you need, these cost $99 but can be got real cheap secondhand or just make them yourself.
here is a link to them to show what they are
Mini-Jacker
most people buy these to make their longshaft act like a shortshaft !!!! this gives them more speed and better all round handling.
under no circumstances cut your transom, that would be crazy and ruin the boat.
you just need a metal box type structure on the back to get the engine away from the boat, idealy 5 inches.
if you have some long metal stud thread you can even use 2 x 5 inch blocks of wood to get it back far enough.
by doing this you get more performanceand more room in the boat as well, its a no brainer.
if i could swap my longshaft midsection for a shortshaft that would fit my engine i would do it straight away.
go look on youtube at the boats they run on the sabine river, it will show you just what jack plates do on johnboats and flat river punts.
with it back a bit you gain around 8 to 10% top end straight away compared to normal longshaft sitting on there !!!!!!
you choose what to do as its your boat and engine, i would go the cheap simple route and keep both the boat and engine the
way they were from factory and just bolt on a bracket.
and one very major factor that often gets forgotten , this means you can run in water 5 inches shallower than a normal set up !!!!
hope this helps
phill
