Re: 1958 7.5 ad-12 carb settings
I thought it worth mentioning that these are only initial adjustments and have to be fine-tuned with the motor running. The high speed can only be adjusted perfectly with the motor running full throttle on the boat. I usually have good luck setting the low speed with the motor running in a barrel. Most of mine wind up about 1 turn on the low and 3/4 turn out from lightly seated on the high, but they're all a little different. Sorry, I forgot to specify which was which!:redface:
Good luck,
That's a nice motor.
JBJ
