I am in the process of returning my 1958 Bigtwin 35 hp (25936) Evinrude to service after about15 years in the garage. When I last used the motor in 1997 I finished off the season by squirting outboard motor oil in the cylinders through the two spark plug holes and slowly turning the flywheel a few revolutions by hand. Before that the carb was run dry. I have added a squirt or two of oil every couple of years and turned the flywheel. The motor is free and turns without effort. The points, condensers and coils were last changed out by me in 1983. I am planning on replacing them as well as the water pump in the next few weeks. This motor always ran well since it was new.
I guess I am asking is what more needs to be done to return this motor to service. I will be removing the head to inspect the cylinder walls and water passages. I also plan to convert it to a fuel pump instead of the pressurized fuel system too. I need to rebuild the pressurized tank tops and I don't want to put the time or money into doing that. I have a couple of old non pressurized tanks that can be used.
Thanks
Tony M.
Thanks
Tony M.
