Hello Everyone,
I was handed down my grandfather's 1957 Johnson FDE-11 just recently and I'm planning to do a complete overhaul after I use it this season. It's been sitting for a long time but my father said he had it running and working fine in a bucket.
No matter what I plan to replace the water pump, lower seal, and gear oil in the lower unit soon. It appears to have sat in the water for some time so I suspect there could be water in the lower unit. I have an order with Iboat set up for:
1957 Johnson Outboard Owner's Manual 376907 - Ken Cook Co.
1957 Johnson Outboard Parts Catalog 377022 - Ken Cook Co.
Water Pump Repair Kit for Johnson/Evinrude 382468 - Sierra
Lower Unit Gear Housing Seal Kit for Johnson/Evinrude, GLM 87606 - Sierra
Will I need the seals for the vent plugs or is that included in the lower unit kit? If it runs do I need to mess with anything else out of the gate?
At the same time I want to switch over to a single line fuel system which is where I really need some help. I've seen various threads and posts and have an idea of where to begin but I would like to start ordering parts if I can before I get my manuals and go through the motor. Anyone done the same with this motor that can give me directions most of the threads I've found are vague?
