Re: 1955 lonestar 14 ft restore
Is the 5th pix of the red & white what it looks like now, or what you intend to bring it back too?
Congrats on keeping the rig, essentially intact (no weird mods to hull & seats) & original, in the family since 1955. Cool!
Welcome to iboats. Vintage tin
:tinfoil3:
Before you completely remove that hull paint, is it well stuck to the hull? Unless you're going to go bare aluminum on the bottom, no need to remove well stuck factory paint......
If you're going to paint the hull, the bare aluminum will need to be sprayed w/ Zinc Chromate or Self-Etching primer before you prime for your finish coat.
The
Starcraft owners forum is extremely active & has lots of good info about working on & restoring aluminum hulls. Might read thru some of the tin resto's too:
Starcraft Rebuilds and Restorations, they're all here!
There are some
Lonestar owners group threads too, but there will be some fiberglass models in there too.
