boatflipper
- Jun 16, 2009
- 500
Today, I added to my already too large of a collection, a 1949 Firestone. I drove a total of 40 miles and paid a sum of $25 to get this beauty...
I return home and immediately go to tinkering.
First, I check to see if I have spark, and, just my luck, none is evident. So, I proceed to remove the gas tank, then the flywheel cover thingy, which was on there very well. I then see a simple set of points, and what looks to be a coil pack. So, the first question is, what should I check first? Should I remove points and clean? Can I even get points to fit? What about the coil pack?
Serial #: 4911-462905
Code#: 133-9-4911
Stock#: 10-A-51
After some digging on here, I pulled up several threads, one on the exact same motor, but noticed they were all fairly old. I also did some research elsewhere and found a good deal of info on these motors, which is a bit reassuring.
Here are some pics, and sorry, I had alrady taken the powerhead housing off before I thought to take pics.
Code#: 133-9-4911
Stock#: 10-A-51
