Re: 18hp starter amp draw
I don't have the manual for the 18. My 15HP starter is rated 55 Amps max (draw while cranking) according to the service manual specs.<br /><br />When buying your heavy duty switch, don't forget that this is 12 Volts. <br /><br />You can probably pick up a used OMC solenoid and use a much lighter switch if you can figure a way to mount it.
