From last week and weekend (sorry I've been slacking off on posting, again)
Measured the width of the hull every 6 inches, transferred this to the center of the plywood. Except for the bow piece I didn't have to do any trimming at all.
Had to remove the port side panel to get the plywood in and out.
Trimmed and rounded off the deck along the engine compartment. I peanut buttered this joint later.
With it being in the 70s and sunny my best man Brian and I wet out and applied a layer of CSM on the underside of the deck. Made sure to wet it soak into the endgrain though some of it came off when I ground off the CSM hanging off the side. We added the reinforcements which also helped to level the deck at the edges. We later added a transverse reinforcing strip of 3/4'' ply to the center of the 2nd sheet for good measure. 3/4'' marine ply doesn't flex much, and 1.5'' really doesn't flex. My '87 BMW K75C is in the background (with its '90s paint fade) and Brian's Mini.
Lugged the plywood back into the boat, drilled all the pilot holes through them and into the stringers and countersunk the pilot holes in the deck.
Deck is permanently screwed down. Brian brought some West System resin syringes which we used to fill the pilot holes with resin. We made two passes since it soaked in a bit. Wet out the top of the stringers and bottom side of the deck where it comes in contact with the stringers and bulkheads. Spread peanut butter on the bulkheads and over the pilot holes. Laid the deck down. Squirted resin onto the countersunk holes for good measure. And finally, ran the screws down. We finished up around 1 am Sunday.
Brian picked up some new 6'' deck plates for access to the fuel tank connections. I jigsawed those holes and sealed the endgrain with resin after the CSM cured on the bottom side.
I'll be back at it this weekend. I have to experiment with deck glassing and gelcoating. Still shooting to lay CSM, roving and CSM, sanding then a couple coats of gelcoat with the traction grit some US-C. Also need to fill over the screws and the gap between the deck and hull sides. I have about 7 gallons of resin left.
http://forums.iboats.com/forum/boat...-repair/297494-if-i-wanted-to-gelcoat-my-deck
8 years ago I posted here about it and it seems that the CSM can be sanded smooth before gelcoating. I'm gonna try doing that with some scrap and seeing how it comes out. The gelcoated deck is a big part of this project so I wanna make it look good.
