I recently got a used 16' aluminum Bayrunner (1987) that is in need of some restoration
I was prepared to replace the wood decks, and rewire, but the hole repair and transom board replacement
is causing some questions. I plan on using this for saltwater fishing and crabbing
I attached some pictures (hopefully) of the backside of the stern, the boat itself and the transom cap and well.
-It looks like the transom cap is actually a shelf and wont come off unless it is cut off and rivets popped,
is that right. If thats the case it doesnt sound like an easy fix.
-If I can get the wood out, I planned on using a sealed laminate of marine grade plywood, any issues with that?
-Will JB weld work to fill the holes on the backside (after I pull the screws), or should I just have a weld shop fix the holes
Any input would be helpfull. I am leaning toward having a weld shop do it if I have to cut the shelf off, since it will need
to be reattached anyway.
