sw33ttooth
- Apr 24, 2011
- 498
currently running a 15x17 prop 3 blades i would like to switch to a 4 blade so i could tube easier plus once i get 5-6 people on board takes a little bit to plane even with trim tabs.
engine: ford 351.
wot rpm: pushing thottle and trimming up to hit 4100-4200
outdrive: omc cobra outdrive.
current max speed wot: 40 1 person 40-55 gallons of gas.
boat hull: 23 foot four winns sundowner.
current prop: michigan wheel aluminum 15x17 a little dinged up but not bent or missing pieces.
i have bernett trim tabs.
recently in shop mechinic said timing was off and set it properly[i think]
now i was told my engine should run in the 4000-4400 rpm range being at 4200 i feel good i was wondering what pitch 4 blade, would give me that rpm area. since i've read you have to play with pitch a little bit when changing from 3 to 4. i've also read about 5 bladed props but i dont have a TON of money to start thowing at somethng like that.
i'd probably like to get a 4 blade ss i know price wise around $400.00 new? but suposibly there better for venting or some odd bs..
also i wieghed the boat and trailer to day a wooping 6240 take off 1200 for the trailer and you get about 5k not sure if thats my speed issue its a cuddy cruiser not a speed demon sadly
engine: ford 351.
