Re: 150 Optimax propping question
If you really give a Rats Butt about how your boat performs, you will want, by all means, to do any and all tweaking you can do to maximize your set-up, if you're not interested in tweaking, then you really didn't want the max potential out of your boat anyway.<br />I can safely say, after running, oh...let's say (for numbers sake)100+ props on the same boat, very few run the same. Now, YOUR Idea of the same and "MY" Idea of the same is likely going to be different..But, the props I started with, running 5700-5800 were mostly 17 pitch...with alot of playing and tweaking, I've greased another 5 inches of pitch, and have kept the 5700-5800. I've increased my speed by 12 mph, and yet I consider 1mph a good improvement, so, you can throw props at it and make it turn the R's you want...or, you can tweak what you have to turn the R's you "Need", or...you can go farther and tweak and test, tweak and test, etc, and increase speed dramatically, which increases fuel milage, again, dramatically...or just settle for what you have....do you really know what you have???? Do you care????<br />That's the difference.
