150 Johnson stalls out of hole then runs good
droutte
My 1989 Johnson 150HP idles good but when I give it gas it stalls out and wont come up on plane.<br /> I put it in neutral, put up the warm-up lever for a minute, then it will run good the rest of the day. Sqeezing primer bulb does not help.<br /> Any suggestions ?<br /><br />Model J150STLCEM
Solittle
Re: 150 Johnson stalls out of hole then runs good
I suspect crud in the carbs - rebuild time for them.
droutte
Already rebuilt the carbs, has had two different power packs, timer base and stator. These were all replaced for different reasons, but I continue to have the stall problem.
foreman33
I have the very same 1989 Johnson 150HP with the same model #. I don't have your problem but I was curious as to what you mean by "put up the warm-up lever for a minute." What is the warm-up leaver? I have a different problem with mine in starting when it set for a couple of weeks. I would greatly appreciate it if you could email me with the procedure that yo use to start your motor. My email address is mewanits@aol.com. Thanks and I hope someone has a solution for your problem.
droutte
Anymore suggestions ?
