111torrance111
- Jan 8, 2006
- 273
150 HP Force Outboard, Model # 1501X91J & Serial # 025739.
I pulled the cover off to see if the controls & cable were working properly, they seem to be traveling the full distance. When it's in the full throttle position you can manually push the carbs open about another .5", I assume this is why I'm losing our top-end speed.
When I look at the arm going up under the flywheel which I assume advances the timing it seems to stop on the motor like it should, as if it won't/can't go any further. But by manually pushing the carbs open I still can't figure out how to get the carbs to open all the way.
Other then this issue the motor runs fine.
Any help/thoughts would be appreciated.
Thanks/Jerry
Thanks/Jerry
