BlueLightSpecial
- Dec 2, 2011
- 152
Ok, The 1987 Merc Black max 150 on my fire dept. pontoon, has a dead short. It blows the 20 amp fuse, near the starter solenoid. Red wire, that goes to pin 8 at the 8 pin connector. The mercury dealer just replaced the switch boxes, stator, and pick up. We need to use the boat tomorrow, and I told them(dealer) this. They gave me a known good ignition switch with an 8 pin, to attach to the engine harness to rule out the control harness. So, the fuse still blows, and i can not find an obvious cause. the red wire with the fuse goes to a splice, where it breaks off into 2 other red wires. one goes to what I believe is either a voltage reg. or rectifier, the other, goes to the hot side of the starter solenoid. Obviously this makes it hot at all times. when the key turned to on, or start, the fuse blows immediately. any help would be greatly appreciated!
