pecheux
- Jun 9, 2006
- 1,200
Good day. My OB runs great most of the time. Start fist pull, good acceleration, great wot speed. I can let it run idling gears engaged in water barrel for hours without any issue. Problem is when I run it on the river it will idle good for a short while. After I run the motor wot for some short burst and return to trolling idling speed it will run good for 15 to 30 seconds then start missing and stops. If I am fast enough to turn the gas handle it will accelerate and reset to normal idling ... only to start missing again 20 seconds later ... problem will repeat until it seems to flud and becomes hard to start. Prior to taking it to the repair shop I would like to have some connaiseur's opinion regarding if the seems like a fuel or electrical problem. thank you all.
