135 hp Mercury outboard intermittent alarm beeping (1988) longterm problem
Sniderah
I have a 1988 135hp Mercury motor (white Mercury - Ser# B334320) on an 18' Searay Seville. I have had an on-going intermittent problem for the last 5 years where the alarm will beep (beep, beep, beep...) sometimes at initial start-up or while running but it is only intermittent. When this occurs I have verified the proper level in the oil reservoir tank on the motor. I have taken it in for service 2 or 3 times and have been told that there is no problem. It is an intermittent issue so is hard to diagnose. The motor runs fine, smokes and maintains 140 F without a problem. I have read all of the posts on this forum related to this issue. This year I hope to figure it out. Here is what I have done this year:
- replaced the oil float switch in the engine oil reservoir tank. After installation, turning the key would give a constant beep. I disconnected/reconnected the water temperature switch, cleaned the terminals at terminal block 14 (insulated), verified the operation of the new oil float switch. This seemed to work. Now turning the key gave 2 beeps to indicate that the alarm circuit was working. I ran the motor in my driveway on the hose. Motor ran well for a bit and then started beeping (beep..beep..beep). Coincident with this alarm beeping, the tachometer needle was going up and down erratically.
- I read a thread that indicated that the tachometer could be a problem. Recommendation was to rotate the cylinder # selector on the back of the tachometer to clean up the contacts. I did this and sure enough turning the key gave the 2 beeps to indicate proper alarm operation. I ran it on the hose again and it seemed to do the trick. Problem solved.
- The next day I checked again and turning the key would give no beeps. I connected the round alarm unit to ground on the tan/blue wire, it sounded correctly. I then cleaned the terminal connections where the oil float, alarm module and rotation sensor are grounded to the engine. Worked again... turning the key gave the 2 beeps to indicate proper alarm operation. Problem solved.
- the next day I checked again and turning the key would give no beeps. I raised the motor up and down, opened up the cowl and then got a constant beep when turning the key. I opened up the clamp that holds the bundle of wires going into the engine and wiggled and tried to identify any obvious wiring issues. I disconnected the 8-pin plug at the engine pulled back the wire loom into the boat and uncovered the bundle of wires to check further back in the boat. I reconnected the 8-pin connector and turning the key would give a constant beep.
Essentially, every time I turn the key (without starting the engine), I will either have no beeps, a constant beep or 2 beeps (proper operation), however, there doesn't seem to be any way to identify cause and effect.
I have a new tachometer on order and I plan to install it this weekend, but I would appreciate any advice on what other diagnostic steps I should take. Another poster had similar problems and resolved his problem by replacing the trigger. I don't understand the electrical circuit well enough to understand how the trigger would be impacting on the alarm circuit and I am not sure if I should tackle replacing it myself.
Any help would be very much appreciated. I don't mind taking it in for service, but I am not confident that they will have the time and interest to diagnose it properly. Thanks.
Sniderah
Re: 135 hp Mercury outboard intermittent alarm beeping (1988) longterm problem
Any insight to help me solve this on-going problem so that I can have an enjoyable boating season would be fantastic! Thanks.
Iceman66
Had the same problem with my 150 Blackmax, had an intermittent failure in the oil warning module,drove me crazy.
Since this engines oil pump is driven by a plastic gear(big weakness) on the crankshaft I removed all the injection parts and
bought a mercury oil pump blocking kit and run mixed fuel.I also removed the warning module.
The cooling alarm will still work,but you dont have the beeeeeep-beep-beep signal when turning ignition on.
Sniderah
Thanks Iceman66. I am not there yet, but maybe soon. I need to find out the answer to this nagging problem.
Iceman66
Well,I am quite sure your warning module has a fault inside, and when affected by the engine temperature, from cold to working temperature,you get this intermittent fault.
Sniderah
I just finished playing with my motor again. I cleaned a number of terminals, replaced the tachometer, reassembled the wiring harness, replaced the ignition fuse (oops!) and then used the CDI troubleshooting guide to check the module. According to the test procedure you are correct Iceman66, the module is bad. I ordered a new one which I will install tomorrow. I saw a really neat site showing what the modules look like inside, rusted and corroded from poor design. My module was replaced once in 1997 as part of my purchase agreement. For this reason I was hoping to buy a CDI Electronics unit instead of Mercury unit, but CDI doesn't have one for my application. I saw another thread that suggested that a CDI unit could be adapted, but I just want to get it working at this point.
Here is the link to site showing the poor Mercury design:
Mercury Oil warning module - failure investigation! - Boatmad.com
Sniderah
I replaced the oil warning module today ($266) and ran the motor in my driveway. Everything seems good now. I will know for sure next time I have it out on the water.
I will dismantle the old module and see if it is corroded inside as expected. Thanks.
Iceman66
Guess you will run great out on the water too, just remember to use a good 2cycle oil,since you choose to run with the oil injection system. Recomend a fully syntetic oil that keeps itself good on the internal and external tank through the winter storage.
You know, it doesnt help with a good working warning circuit ,
if oil pumps inside and oil lines get plugged with jelly fragments and debris from a cheap oil.
RoncoRon
I fixed same problem after many trips to SeaRay. In the oil injection reservoir inside there is a supply tube this tube has screen filters. Slime builds up & doesn't let the oil flow properly. Screen is to fine. I used safety pin poked holes thru the screens. Alarm stopped Ron
Faztbullet
That IS not a repair or fix! Now you risk transferring this slime through oil system. When oil "jellys" in the tank the repair is to clean tank and change oil
