jerryjerry05
- May 7, 2008
- 17,927
Gear oil: 32+ oz. I fill till it comes out the vent and then fill the vent till it comes out the fill.
uses a bit more but that way I'm sure it's full.
Trim @ Tilt fill when all the way down. Add oil 30wt. then cycle it up and down. Then add more while down.
NEVER add oil when it's in the up position. You can push oil up into the electric motor.
Running at idle, skip : the air screws need adjusting. Turn in till lightly seated(remember the turns) then out 1 and 1/2 turn.
That's the base setting for initial adjustment.
Look up starting procedures. I/E fast idle, choke.
Stiff throttle: unhook the connector at the motor. Have someone spin the prop as you shift. try shifting as they spin the prop, is it still stiff?
Might be a bad cable? or linkage needs reset.
The throttle advance arm is held on with a 7/16 nut. Loosen it just a tiny bit. It's supposed to be tight but not so tight as to stop the throttle.
