All parts from old block to new(used) block except distributor and carburetor. New block sat unused for several years. Idle good. Can not get full power. Feels as if the engine is starving for gas. Occasionally get a 3 to 4 second burst of full power then back to the "starving" issue.
Gas is fresh. Filters are new.
Questions. I know the carb on the 120 is good. Can I swap to the 140?
Any other thoughts on this problem?
Going to take the extra fuel pump along on the next outing if the carb swap doesn't work.
If the carb is at issue, what should I be looking for?
Hope this makes sense.
Again, thanks for the forum and all the excellent advice here!
